SailNet Community - View Single Post - Using a temporary mooring
post #25 of Old 04-09-2007
sailingdog
Tenuki-
that is correct... all a mooring really is, is an anchor of some sort with a permanently attached rode, that you connect your boat to. Scope is generally less of an issue, since the scope should have been set when the mooring was placed. Some mooring anchors, like the Helix Screw anchors, require less scope than others... The three anchors set in an equilateral triangle type mooring also doesn't require all that much scope, since much of the scope is already laid out along the bottom, where the three anchors are joined at a swivel.
sailingdog is offline
