Asym Spinaker-Sprit and RRS
Here ya'' go guys..Looking for some input on this one. I''m trying to get more performance out of an asym. This should get some real comments:
I think I figured out a way for a sprit for my asym spin. OK, it is permitted to pole out an asym spinnaker.
The normal method is from mast mounting to the clew. The asym normally has a tack line which runs through a turning block mounted forward of the forestay on the bow then it runs back and is secured to the cleat on the foredeck.In this configuration the tack of the asym is about 4 foot above the deck and only inches forward of the forestay.
My change, which I think would not violate any rules; is that I would take my whisker
pole and mount it on the normal mast fitting but let it drop down to the bow pulpit and secure it with a "fixed downhaul". Then mount the turning block in the forward jaw and lead the tack line through the turning block back to the foredeck cleat.
The advantage to this arrangement is that by extending the turning block 3-4 feet ahead of the boat is will let the asym to a better job of ''pulling'' the boat.
I looked through the rules and I think this might fly...
