Old 04-10-2007
sailingdog sailingdog is offline
Yes, I've noticed that the women generally take over a lot of space and get things their way, or you end up suffering the consequences. If you're really worried about the higher holding tank, up forward, you could put either a check valve or a ball-valve into the hose to prevent a failure of the joker valve from dumping waste into the head.
Unless you've designed the holding tank poorly, an anti-siphon valve isn't needed, since the air vents in the holding tank will break any siphon effect, unless you've over-filled the holding tank, in which case—you're basically screwed anyways.
