Chafe is going to be a huge problem with the boat on a rope going through a block. If you had photos or a diagram, it would be easier to make suggestions for your situation.
You will definitely want to get the 10' 2"x6" as sailaway suggests, to use as a gangplank.
(sailaway, it's technically a block, not a sheave.. a sheave is a pulley inside a mast or boom, when it is outside of a spar, it is a block.)
