SailNet Community - View Single Post - Thru Hull Fittings
post #4 of Old 03-26-2002
Peter_pan
Thru Hull Fittings
The plunger is a good idea but you don''t need a water hose. If the hull is smooth, grease it up with some vasaline close the valve and stuff the plunger over it. If it falls off it leaks. After all, if it will leak air, it''ll leak water.
Ole Pete
Peter_pan is offline
