SailNet Community - View Single Post - SSB antenna
Thread: SSB antenna
post #2 of Old 04-12-2007
sailingdog
While you don't say what the boat is, there are other ways to setup an antenna and ground plane for SSB. If the boat has a metal hull or large metal tanks down below, for fuel and water, you can often use those to create a large ground plane fairly quickly.
There are also antenna designs that do not require a ground plane.
sailingdog is offline
