Can somebody figure out my PHRF
A couple more thoughts here, there is a real problem with handicapping boats like yours. If you compare more traditional designs to more modern designs, modern designs have a big speed advantage in light air where their lighter weight and bigger sail plans really keep them moving and allow them to sail from gust to gust so that, with a little skill, they sail in more wind more of the time. They often have a real advantage in heavier air as well, where their easily driven hulls and ability to depower quickly allow modern boats to go upwind very and with less leeway and to then power off surfing and planning down wind. So at the extremes they have an obvious speed advantage over more traditional craft. But when you look at how PHRF ratings work, the rating is really about the prevailing winds in the region and that usually means 8 to 12 knots of air. In those conditions Modern boats really do not have such a big speed advantage, so in theory their ratings should be closer to a more traditional boat based on those conditions than perhaps common sense would normally suggest.
Here is where the art of handicapping comes into play. Handiacappers will often raise the ratings on more traditional boats to give them half a chance closer to the extremes. If you have a season with the actual average winds this helps a traditional boat do well, But if you have a season where the majority of the winds are at the extremes then it gets quite difficult for a traditional boat to hold its own. I am speculating that your rating was juiced a bit and that you have been doing well in small part because of that. Its rare that a rating change of 6 to 9 seconds or so will affect a boats place of finish on short courses in light conditions, but in heavier going or longer races this can really add up to a win or loss.
