Foam cored dark decks are even worse... you can leave permanent foot prints in them. BTW,
epoxy weakens quite a bit with heat...so much so that most manufacturers of
epoxy resin tell you not to
paint the parts dark colors if they're going to be used in sunlight. Dark colors can also cause the resin to post-cure and leave the fiberglass cloth printing through.
POST.
