SailNet Community - View Single Post - Refurbishing portholes
post #2 of Old 04-12-2007
sailingdog
smallyatchs-
It would help if you said where you were located as well as what kind of baot that you were working on.
You may need to use a razor to cut the bedding material away from the glass. Then remove the glass. After the glass is out, you can remove whatever bedding material is left.
You could contact a local glass company to find out about getting replacement seals. The bedding compound that they're using might be a butyl-rubber gasketing compound that is often used on car windshields.
sailingdog is offline
