SailNet Community - View Single Post - Should I be scared??? What would you do???
post #8 of Old 01-26-2014
davidpm
davidpm's Avatar
Re: Should I be scared??? What would you do???
How good a sailor are you?
Are you going to be able to evaluate the boat under sail? Do you have the skills to recognize a problem if there is one?
I can't imagine buying a boat without sailing it. I wouldn't by a car without driving it. I wouldn't buy a guitar without playing it.
If I was buying a horse I would not need to ride it. I don't ride. There is little I could learn from a test ride. I would even know what to do or what to look for.
Giddyap!
If the seller of your horse refused to let you ride test it you would have reason to believe that the horse had something wrong with it.
Even if you couldn't ride but watched someone else ride you might notice if the the horse couldn't even get to a run.
Or if it did run was obviously over heated.
But yes someone who knew how to ride would probably get more out the ride test.
davidpm is offline
