SailNet Community - View Single Post - Cooling problem solved now what's wrong with my tach?
post #2 of Old 01-26-2014
Faster
Re: Cooling problem solved now what's wrong with my tach?
Do you have an ammeter or a battery monitor? Tachs on diesels are either run off the alternator or a pickup off the flywheel, usually a single wire sensor bolted into the bell housing/adapter. If the tach is off the alternator and it quits that's usually brushes (or a dropped wire) but if it's brushes then you won't be charging either.
Your loose wire is the first place to look.
Faster is online now
The Following User Says Thank You to Faster For This Useful Post:
tspooner (01-27-2014)
