SailNet Community - View Single Post - Cooling problem solved now what's wrong with my tach?
post #3 of Old 01-27-2014 Thread Starter
tspooner
Re: Cooling problem solved now what's wrong with my tach?
Thanks Faster! During my cooling issue problem I started at the saltwater seacock and checked the flow all the way through the system to the mixing elbow. I also found that the sea water strainer unit was old and corroded enough that it was going to cause me grief sooner or later and so replaced it with a new one. It's likely that in that cramped and dark working area I may have snagged a wire at the bellhousing. I'll check that area out next weekend as I doubt my unidentified loose wire will reach the alternator.
tspooner is offline
