SailNet Community - View Single Post - Cutlass Bearing needs to be replaced on a boat Im looking at
post #3 of Old 04-13-2007
S/VNirvana
SONNY
S/VNirvana's Avatar
I have done it myself and it is not as easy as you would think it could be or should be. The hardest part of the entire job is getting it out without doing any damage. If you do it slowly and not rush the job; you will get good results. You can use a nut, bolt and washer if you can't get or rent the puller.
Sonny
s/y NIRVANA, SO49
S/VNirvana is offline
