SailNet Community - View Single Post - Embedded Chain plate maint/replacement
post #143 of Old 01-29-2014
Total Chaos
Re: Embedded Chain plate maint/replacement
You are still talking about adding a backing plate then to the outside of the hull right? Unless you use load distrubting plates like the original and reglass them, you would still need polished plates on the outide of the hull if you use any bolts at all. Am I missing somthing?
Total Chaos is offline
