SailNet Community - View Single Post - Embedded Chain plate maint/replacement
post #144 of Old 01-29-2014
Stumble
Re: Embedded Chain plate maint/replacement
Originally Posted by miatapaul View Post
And it avoids the Ugly bit of having the chain plates bolted to the exterior of the hull. I think it looks like a "cheap and easy fix" when on a boat that did not have it originally. It does make them easy to inspect though.
That's because it is a cheap fix. I don't like external chainplates on any boat, but if I saw them on a boat that wasn't designed with them I would walk away.
The major problem with moving to external chainplates is that they have a larger failure area than on penetrating ones, and are covered in salt water much more commonly.
It really concerns me that people constantly want to mess with the work of a professional NA in such a substantial way without checking with a qualified expert. Swapping around chainplate locations is like moving around the structual walls of your house. Sure it might be ok, but it wouldn't do it without checking with an architect.
Greg
Stumble is offline
