SailNet Community - View Single Post - Embedded Chain plate maint/replacement
post #145 of Old 01-29-2014
Total Chaos
Re: Embedded Chain plate maint/replacement
The only neg effect moving the chains farther outside is on the ability to close haul, in this case it is only couple inches otherwise the plates are in the same location. The effect on the rig is to actually make it stronger... the base is wider. As to the cosmetics to each his own. The one absolute fact about glassed in plates is that they are 02 starved and water will get in there eventually, 30 years down the road, or 2 and along with that comes crevise corrosion. The only way to inspect these plates is to have gamma radiography done. $1500 just to inspect the plates, hmmm pass.
Total Chaos is offline
