SailNet Community - View Single Post - Is it useless: NMEA2000 In-line terminator
post #5 of Old 01-29-2014 Thread Starter
Reefpoints
Re: Is it useless: NMEA2000 In-line terminator
Originally Posted by Tim R. View Post
There should be a resistance of 60 ohms. Try testing between the pins at the end where the wind sensor connects.
Have you tested an end terminator. Which pins provide the specified resistance?
Thank you! You pointed me in the right direction.
Across the network connections pin 4 (data hi) and pin 5 (data lo) in the diagram below there is a resistance of approx 120 ohms in both the end terminator and the in-line terminal.
Now that I can see that it's doing something, it'll get installed. What's one more hole drilled into my mast anyway..
Reefpoints is offline
