SailNet Community - View Single Post - Adding a auxiliary outboard.
post #4 of Old 01-29-2014
Shinook
Re: Adding a auxiliary outboard.
Make sure you use a mount that is spring loaded to assist with the motors weight and has enough travel to get deep in the water.
How thick is your transom? I'd think a 1in backing plate would suffice. We mounted one on our boat, but the transom on ours is 1/2in thick. We used a 3/4in starboard backing plate and washers, it has held up fine.
Shinook is offline
The Following User Says Thank You to Shinook For This Useful Post:
Zuma (02-04-2014)
