SailNet Community - View Single Post - Sailing "big boats"
post #7 of Old 01-31-2014
Re: Sailing "big boats"
I used to sail duo an heavy 60ft steel boat and that was a big task for two (I was a lot younger and foolish). I doubt I would have done it now.
The difficulty of sailing a boat between 50 and 60ft has much to do with the weight of the boat. If it is a modern light one then it will need a lot less sail area and everything will be easier. Also it has to do with rigging. A lot was learned on the last 20 years regarding rigging for big boats solo sailed and a modern rigging adapted to it will make things much more easy.
Regarding interior space more modern boats have much more interior space and you can have the space you have in your boat probably in a boat 10ft smaller.
The big problem of managing a big boat has to do with docking maneuvers. Today not only the boats are lighter (and that makes it easy) as they have computerized docking systems that work with a joystick and that give to the boat the same agility of a smaller boat.
The problem with all that is that modern boats are expensive (because they are not old)...but maintaining an old one is expensive too.
