SailNet Community - View Single Post - Embedded Chain plate maint/replacement
post #161 of Old 01-31-2014
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Embedded Chain plate maint/replacement
Originally Posted by chucklesR View Post
The primary reason I went for internal vs external was the cost - electro plated plates are x5 the cost
Not sure what you mean by this. Were you looking at having them chromed? Or did you mean electro POLISHED?
If the latter, it only costs a few bucks - far less than the cost of the new chains being cut & drilled. It's well worth it too as the finish lasts WAY longer.
It also precludes crevice corrosion as there is no surface iron left to give it a path into the metal (as long as the electro surface lasts).
SloopJonB is offline
