SailNet Community - View Single Post - Sailing "big boats"
post #20 of Old 01-31-2014
outbound
outbound's Avatar
Re: Sailing "big boats"
TC - most impressive . Yes you truly need the space. People forget sometimes we all need some quite time ideally behind a closed door or up on the fore peak by yourself. With teens I expect that's even more apparent.
Other issue is at about mid forties wind vane self steering becomes less effective. Boat is moving faster and displacement greater. Then there is even more dependency on having electricity. At mid forties when the lights go off you can still sail the boat.raise,reef and strike.
People forget cruising isn't day sailing. Usually the main goes up and stays up a good part of the time. Even motoring if there is any wind you power sail when you can. Been debating about hydrovane v. second A.P. Design of stern makes any servo pendulum less appealing. And ease of having emergency rudder sounds nice with simplicity of hydro vane. ? Do you have backup if rudder fails.
s/v Hippocampus
Outbound 46
outbound is offline
