Old 04-18-2007
sailingfool sailingfool is offline
ASA and PSIA Instructor
Paint removal
If the paint on the bottom is still adhereing properly, i.e. not flaking off in numrous sections, touch up where needed and then apply another coat of ablative paint. If paint is flaking off then you need to figure out how to remove it, its either a terrible job or an expensive job, depending on who does it (you or a yard). Good luck.
Put ablative paint back on, you'd be nuts to use anything else. Consider a hard finish only if you race the boat and want every edge. Many racers I know still go with the ablative paint.
