SailNet Community - View Single Post - Sleeping preference?
post #26 of Old 02-02-2014
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Sleeping preference?
Originally Posted by DRFerron View Post
I read a tip on someone's cruising blog to use the Queen fitted sheet with the corner at the V of the berth. I tried it and surprisingly, it is a LOT easier to get on the V-berth cushions than crawling and tucking a flat sheet. Also, that V area doesn't come off in the middle of the night. The rest of the sheet is easy to tuck under the rest of the cushions and all stays put quite nicely.
Not heard that one before .... sounds good though, must try it. The Wombet has been threatening to cut and resew fitted bottom sheets but thus far talk is all it has been.
btw ... back in my furniture making days I had a mattress made up of three different foam densities with a double thickness of wadding on top. Fabulous mattress and the wadding kept it cooler than plain foam.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
