Pmoyer-
Glad to help.
I would recommend you shock treat the water system, flush it with fresh water several times, then change out the hoses, and then re-shock treat the water system, and flush again. Then do a final flush with some vinegar, to help get rid of the chlorine aftertaste.
SVDS- This same treatment might help with your 30 gallon tank and make the water useable for non-potable uses.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
