SailNet Community - View Single Post - Anti-Fouling Paint on an outboard?
post #12 of Old 02-04-2014
pdqaltair
pdqaltair's Avatar
Re: Anti-Fouling Paint on an outboard?
Originally Posted by ericb760 View Post
Thanks, but I don't think it's really rocket science. I figure I'll sand the old and peeling paint off, hit with some aluminum primer, and then spray on the anti-foul.
a. Unless you've figured out how to paint the inside of every passage you'll get growth inside. On inboards there are 2 differences; the passages are larger to allow for this; when the seacocks are closed there is no oxygen in the water and this tends to kill everything.
b. If something grows in there, you might just need a new engine. And something will.
c. Try this expereinment. Wrap some duck tape on a couple of blades, not floppy but not skin tight. Feel the vibration and note the loss in speed. It doesn't take much on a high speed (relative to inboard props) prop to desroy the flow.
I really don't think you want to do this. I'm not sayin' you can't, I'm just sayin' you'll be worse off.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
