SailNet Community - View Single Post - Extreme Cold
Thread: Extreme Cold
post #85 of Old 02-04-2014
Delta-T
Delta-T's Avatar
Re: Extreme Cold
No worries if you want to burn your boat down with using bulbs to heat in a confined space, CFLs, although generate no heat the integral ballasts do. And same goes of LEDs. You can put them closer to the sea cocks without as much risk of fire. Just a piont about the new wave of lighting and heat, I would never recommend using such a method.
Edit: IMHO, though that was a given.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
