SailNet Community - View Single Post - Extreme Cold
Thread: Extreme Cold
post #88 of Old 02-04-2014
Delta-T
Delta-T's Avatar
Re: Extreme Cold
Can you cite an example where this actually happened?
Here you go from the NFPA: https://www.nfpa.org/research/report...ses/electrical
"In 2011, an estimated 16,400 non-home structure fires reported to U.S. fire departments involved some type of electrical failure or malfunction as a factor contributing to ignition. These fires resulted in 13 civilian deaths, 243 civilian injuries, and $501 million in direct property damage. In 2007-2011, non-home electrical fires represented 13% of total non-home structure fires, 5% of associated civilian deaths, 13% of associated civilian injuries, and 21% of associated direct property damage.
Half (48%) of 2007-2011 reported non-confined U.S. home structure fires involving electrical failure or malfunction had some type of electrical distribution or lighting equipment as equipment involved in ignition. The leading other types of equipment involved in ignition were fan (6%), washer or dryer (6%), space heater (4%), air conditioning equipment (4%), water heater (3%), and range (3%).
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
