SailNet Community - View Single Post - Standing rigging replacment
post #4 of Old 04-21-2007
sailingdog
Valiente-
I don't believe that StaLok terminals work on Dyneema, which is a fiber found in high-tech ropes made from ultra-high-molecular weight polyethylene. I believe you meant Dyform... which is a stainless steel wire that uses shaped wires to give more strength to a 1x19 wire rope cable.
I would recommend you also look at Hayn HiMod terminal fittings, as they are reusable and a bit simpler to use.
sailingdog is offline
