SailNet Community - View Single Post - Standing rigging replacment
post #6 of Old 04-21-2007
Valiente
Valiente's Avatar
Valiente-
I don't believe that StaLok terminals work on Dyneema, which is a fiber found in high-tech ropes made from ultra-high-molecular weight polyethylene. I believe you meant Dyform... which is a stainless steel wire that uses shaped wires to give more strength to a 1x19 wire rope cable.
I would recommend you also look at Hayn HiMod terminal fittings, as they are reusable and a bit simpler to use.
Thanks, I did in fact mean Dyform. I've bought ten grand in boat gear since January as we are well into fitting out the boat, and my mind is swimming in product names and proprietary terminology just as my printer is spitting out "fact sheets" for how to apply primer in a north east wind on a Tuesday...very special needs stuff, apparently.
Valiente is offline
