SailNet Community - View Single Post - Extreme Cold
Thread: Extreme Cold
post #102 of Old 02-05-2014
lightfoot
Re: Extreme Cold
Originally Posted by hellosailor View Post
Hi wattage, low wattage, specialty, halogen, many types of filament bulbs are still available and being manufactured.
But if you want to keep something warm, look for "heat tape" in the plumbing section. Or for infrared heat lamps (typically reflector spot type) in the store. The heat tape is designed to keep pipes from freezing up and there's no filament to burn out.
Incandescent bulbs are (were) cheap and convenient, but there are better ways to generate heat.
The problem with "HEAT TAPE" is that they are normally at least 6 feet long, and you only need about 3-6 INCHES of the stuff to adequately warm up a typical thur hull fitting.
lightfoot is offline
