SailNet Community - View Single Post - outboard for sailboat?
post #7 of Old 04-22-2007
Boasun
Boasun's Avatar
It sounds as if you cracked the block of an inboard engine!? If this is the case then replace that engine. The weight of the inboard is figured into the stability of your vessel. So replace it. Whatever you do don't take out the old one for the above reason with replacing weights required below.
Boasun is offline
