SailNet Community - View Single Post - Rot in Bulkhead C&C Invader 36 (Frigate)
post #4 of Old 04-22-2007
sailingdog
Of course, the best solution would be to remove the bulkhead and replace it completely.
However, whatever method you use to fix the problem area... don't forget to seal the plywood with epoxy and then to pot the holes for the chainplate fasteners, much like you would with a cored deck. That way, any leaks at the chainplate will result in a wet interior, but won't cause any future deterioration of the bulkhead.
sailingdog is offline
