SailNet Community - View Single Post - How much water is normal?
post #27 of Old 02-06-2014
ahab211
No one seems to think it is loose keel bolts? An older boat with a crack line on the keel joint and that leaks from that needs them tightened and the joint sealed at the least! I sealed the joint on my Catalina 27 on the hard and will tighten the bolts In the spring as they are steel and not easy to get a socket on! Good luck.
ahab211 is offline
