SailNet Community - View Single Post - Organizing the running rigging... need help and advice
post #4 of Old 04-23-2007
sailingdog
You cut a slot for each and then you put a metal plate that has a nicely shaped opening that is rope friendly into the slot and bolt or rivet it into place. Try not to have the mast exits for the ropes aligned either horizontally or vertically with each other, as that will be more likely to cause the mast to fail. Spacing them about a foot apart from each other on each side of the mast and staggered vertically is usually a good way to do it.
sailingdog is offline
