SailNet Community - View Single Post - Major Damage!
Thread: Major Damage!
post #3 of Old 04-24-2007
camaraderie
moderate?
camaraderie's Avatar
JR...the yard could very well be right. Have they ground down through the gelcoat and does the crack extend THROUGH (not TO) the woven roving? Are you seeing any water ingress into the boat or can you see the crack from under your floorboards? I agree with the need for a surveyor to take a look as whatever has caused this may need to be attended to before a fix in the glass is made. On the other hand...this may just be some gel-coat flex cracking in which case it should not be a big deal at all. You need a pro to look at it.
camaraderie is offline
