SailNet Community - View Single Post - Organizing the running rigging... need help and advice
post #8 of Old 04-24-2007
christyleigh
christyleigh's Avatar
I wouldn't get too excited about running the halyards through the mast just yet as you are looking at a lot of time and money. Since you are still going to need turning blocks at the mast base any way I would set them up (if possible) to be used either way so if at a later date you decide you want to run them inside. All the other stuff is a bit more straighforward but I know I wouldn't even want to consider the work involved in running them inside a mast that was not designed for it.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
