post #6091 of Old 02-08-2014
EricKLYC
EricKLYC's Avatar
Re: Interesting Sailboats
Originally Posted by capt vimes View Post
Regarding the kuka light...
I am a little surprised that the kuka is with 3.2 t only 800 kg lighter than an plywood epoxy boat in her race trim one could build in his garage...
Didi 40cr radius chine plywood sailboat
And this homebuild boat has aluminum spars, 1.5 m less draft and 2 t ballast in a conventional keel casing made of steel... I imagine that the kuka has probably a little more than 1 t in her canting keelbulb...
If i look at the effort those guys put in to build the boat, i come to think that her lightness is not that extraordinary, just expensively bought...
And i know you cannot compare these two boats... The kuka has way more power, more sailarea and is by all means a lot faster... I just looked at the weight figures...
Isn't 20% or 800 kilo's still quite a lot, even more than the weight of crew + full gear?
Best regards,
Eric
EricKLYC is offline
