SailNet Community - View Single Post - planning to buy: steel hull / wooden deck
post #2 of Old 02-09-2014
Classic30
Once known as Hartley18
Classic30's Avatar
Dock
Re: planning to buy: steel hull / wooden deck
Nice boat!
IMO, there's nothing wrong with composite construction - Clipper Ships pioneered that idea centuries ago - so long as the deck is fastened to the frames properly, there should be no issues to speak of unless someone screwed something into the deck without sealing it properly.
Just make sure you look for deck leaks (with tell-tale rust trails) overhead when you're doing the inspection down below.
Classic30 is offline
The Following User Says Thank You to Classic30 For This Useful Post:
freebirdsailing (02-10-2014)
