Swept back spreaders
monark192,
The main purpose of swept back spreaders( vs those perpendicular to the mast on a rig) is to allow tighter sheeting angles for the genny? This typically translates to pointing a few extra degree''s higher.
This is how the boat was designed, and as Jeff said I am not so sure I would go to all sorts of changes as it would be a major hassle. But, more importantly, it might drasically change your boats sailing characterisics. Swept back spreaders in and of themselves are not there to prevent the mast from pumping that would be function of the your stays . But if you "did" go to a perpendicular spreader AND you have a backstay (as you described) then you probably won''t need running checkstays or running backstays and you will end up with a very tradional (and sturdy) single spreader rigged boat.
I would pose this question at a very good site on rigging for Boats its http://www.briantoss.com/ and you can post the question in the "SPARTALK" section.
