SailNet Community - View Single Post - Connecting raw water cooling to water heater
post #5 of Old 04-26-2007
sailingdog
The thermostat is designed to open when the engine coolant reaches an operating temperature of about 180˚ F. Once, the raw water has passed through the heat exchanger, it is likely to be well over 100˚ F. Home water heaters are usually set around 140˚ or so... anything hotter will risk scalding. BTW, diesels run pretty hot, due to the ignition temperature of diesel fuel... so if the engine is running under any sort of load, the raw water side will be pretty hot.
sailingdog is offline
