Old 04-27-2007
sailingdog sailingdog is offline
I believe the water intake was left off the drawing to simplify it... and not confuse the novice boat plumbers...
This setup with the modifications I've indicated is designed to allow flushing into the holding tank or directly overboard, as well as pumping out the tank via the pump used to flush the Lavac head, or via a deck pumpout fitting. It is also designed to only require one pumpout fitting or connection on the holding tank.
