Had a 2nd look at a picture of my engine area (will not be back at the boat for 2 weeks). I do not think that the water heater hose will be higher than the hot water hose, coming off of the engine, so I should be OK. I can probably lower the water heater a couple more inches as well, as the old one was sitting on a "stand" of 2x4s, that span the gap over the prop shaft/ back bilge area. I can probably use a thinner material, than 2x4s, to make this water heater stand a bit lower.
