SailNet Community - View Single Post - Icebox Drain
Thread: Icebox Drain
post #4 of Old 04-29-2007
sailingdog
Generally, I don't recommend draining an icebox into the bilge if at all avoidable. Food particles and such often end up in the ice box water, and then in the bilge... and that can lead to a very nasty smelling bilge after a while. Draining to the shower sump makes the most sense, but on many boats, this isn't all that feasible, since the head and the galley are far from each other. Another option would be to install a small shower-type sump with pump for the icebox drain.
The drain to the icebox should have a trap, like that you'd find under a sink otherwise, not only will the water drain out, but most of the cold air as well.
sailingdog is offline
