SailNet Community - View Single Post - To Rebuild or not to Rebuild that is the question
post #6 of Old 02-14-2014
newhaul
islander bahama 24
newhaul's Avatar
Re: To Rebuild or not to Rebuild that is the question
Originally Posted by Lake Superior Sailor View Post
Rebuild it! easy compared to a gasser.. I would run it first and see if you really hurt it. Could be your listening too hard....Maybe get a compression test....Dale
Do two compression tests cold and hot if pressure comes up when hot likely ring job will do if no change head removal and close inspection had a truck like that one cylinder had broken rings when heated up it sealed the compression and unless a shop says not rebuild able rebuild it.
Illegitimus Non Tatum Carborundum.
newhaul is offline
The Following User Says Thank You to newhaul For This Useful Post:
CaptainRahnn (02-14-2014)
