SailNet Community - View Single Post - To Rebuild or not to Rebuild that is the question
post #11 of Old 02-14-2014
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: To Rebuild or not to Rebuild that is the question
At least change all the fluids before going any farther. Overheating cooks engine oil and coolant.
A compression test would be the next step.
Then read Porfin's as yet unfinished thread about re-building his 4108.
If a fresh engine is needed, definitely rebuild it - a swap is a huge job and will cost WAY more than the already shocking cost of a new crate engine - 30%-50% more if you do everything yourself, probably double if you just write cheques. Either way a new crate engine, installed, will cost as much or more than your boat is worth.
SloopJonB is offline
