SailNet Community - View Single Post - To Rebuild or not to Rebuild that is the question
post #13 of Old 02-14-2014
desert rat
Re: To Rebuild or not to Rebuild that is the question
Newhaul hit it on the crank. Compression test cold and hot. Diesels are almost like gass just higher compression. Every engine needs oil pressure and temp sensors. If you haven't changed the oil you can do an oil analisis. As you can see I can not spell.
Zen is a matter of recognizing reality.
desert rat is offline
