Old 05-02-2007
thusly thusly is offline
thusly is on a distinguished road
It sounds like a fuel delivery problem. Have you checked your priming pump? It may not be 'tight' due to corrosion and/or leaky diaphram. If this is the case, you can try to bypass this with a rubber priming pump jammed into the bleeding port and some gas line going to the tank.
Good luck.
