SailNet Community - View Single Post - Autopilot install with a switch
post #4 of Old 02-16-2014
mitiempo
mitiempo's Avatar
Re: Autopilot install with a switch
Originally Posted by tcase10 View Post
I got an used autopilot for my Catalina 27 (wheel). I don't have a dedicated switch on my fuse panel for my instruments. I will add that in the near future when I replace the non working depth and speed. Today I installed the autopilot and wanted to put it on a switch in the cockpit. I have attached a photo of the switch. I am running directly from the battery to the switch, then off the switch to the control head, with a fuse inline. I connected the negative to the battery and then connected the positive. All worked as it should, except I realized the switch was in the on position. I flipped the switch off and went to put the positive back on and it created a large spark. It then removed the negative, installed the positive and tried to install the negative and had the same issue. The ring terminal even tried to weld to the battery post.
What am I doing wrong?
Looks like you have both positive and negatives on the switch - in the on position a dead short. Switches only control the positive wire. The only time a negative is used on a switch is if it has an indicator light that needs it.
You should have the negative going to the autopilot. The positive goes to to one side of the switch and from the other side to the autopilot. Fuse the positive close to the battery.
Brian
mitiempo is online now
