Originally Posted by Cruisingdad
Just one quick comment on setting an anchor: You better get good at it and learn to feel it without diving it. Diving it is fine in clear, warm water. However, much of your cruising will be in mangroves or brackish water that will not allow you to dive your anchor. A trick we use is to back down hard (after we have set it) and hold the chain. It takes a little getting used to, but you can feel it bite or drag. Takes practice, but worth it.
- CD
Or in the case of the Acushnet River, a superfund site, laden with PCBs that you wouldn't want to go diving in...
Jason-
The next generation anchors are the newer designs that include the Rocna, Spade, Manson Supreme, Buegel, Bulwagga and XYZ anchors... most of which are far more resistant to moving through the seabed than the more traditional designs.
The chain is to make the rode heavier and force it to hang in a catenary curve, so that the pull against the anchor is almost horizontal, rather than upwards. It is also good to have chain since it is much less susceptible to chafing—which is particularly important in rocky or coral-laden areas.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
