SailNet Community - View Single Post - Voyaging on $500 per month
post #1128 of Old 02-19-2014
Lou452
sunfish?junior?
Re: Voyaging on $500 per month
Originally Posted by Group9 View Post
I used to use a lead line all of the time when I first started sailing. My first sailboat had no electronics except an intermittent depth gauge (it only seemed to work in water that I knew was deep enough) and a VHF radio (which we could use to use to make phone calls back then if we kept out later than we planned and you would actually read your credit card numbers off to the operator (to show how innocent the world was back then), or make it collect). I made my lead line from an old window weight.
A fishing pole and a bobber is a good tool. Use a small bobber and a large sinker. You can set your depth. If the bobber sinks you should float. You can find the shallow water as far away as you can cast. The keel can find all the shallow water right next to the boat.
Kind Regards, Lou
Lou452 is offline
